Old, thanks. We struggled a bit getting the inner hub all lined up and back in but once it was lined up, it greased right in. The fuel lines under the tank were a royal pain, just like everything else. The brass connectors on the bottom of the tank were ancient, bent up, and threads half gone. No one around here had anything like them. Finally raised the tank back up a couple of inches to give us some working room, lossened the line support connectors up where they are held on near the seat brackets and Walt was able to get them back on. That was after I had worried with them for two afternoons!
We began the process of hooking up the hydraulic lines to the tank and figured out the replacement hose I bought for the return line was too stiff. Got to go find that somewhere today. None of the local supply houses had the inch and half size required. Got the output line reconnected. Once the hydraulics are connected, we can refill the fuel, hydraulics and transmission with fluid and start the Beast. She hasn't been started for 4 months so that should be a chore!
