Final Drive is OUT!
:notworthy Success at last. Thanks to all your advice and help, we got the final drive out Saturday. Friday, we got the tank assembly off, not without some problems. Whomever put the suncover/ROPS on the Beast welded the ROPS to the deck and in doing so, partially captured two each of the horizontal bolts that hold the tank plate in place
. So, it was back to town on Friday to haul the torch and bottles out to the ranch to cut the welds and part of the ROPS plate out of the way so we could get the bolts out. We wound up cutting one of the bolts on the left side out, it was just too much trouble to cut around the ROPS to free it up. We used friend Walt's winch on the front of his Kubota gator to lift the tanks off, worked like a charm.
Turned out the ripper buffer was not even hooked up!, Just a dummy assembly sitting there, the hydraylic line was capped off. We'll try hooking that up when we re-assemble.
Once the tanks were off, we could see our power washing had not done as much as we thought, ugly under there. But the area to get at the two bolts we needed to free the final drive was clean enough, so we got the long extension and 15/16" socket on them, 8 foot cheater and they popped loose easy. Using a short lenghth of parachute cord to tie the brake actuator lever out of the way, a pry bar to lever the final drive loose, it came right out.
The pinion shaft turned out to be held in by 2 circlips. We had to take the brake pack apart to get out the 2d inner circlip.
The pinion shaft we received as a replacement will probably not work. We thought we could take it to a machine shop and have the circlip slot cut into it, but the inner slot is off the spline area and no way to lengthen the splines I can see; too thin in the shaft size in that area.
Other than finding a correct pinion shaft, one inner shaft seal and a replacement boot for the brake actuator cable, we are probably good to go for reassembly. Hopefully that won't take too long. We start work at 0600 and have to be done by 1100, it is just too hot otherwise. We will powerwash next weekend and begin reassembly if we can get the parts!!
