More work to be done!
While it has been down, I finally pulled the belly plates and cleaned that area out, geeze what a mess. As with yours, there must have been 10 years worth of dirt junk, lost bolts and tools and geasey muck piled up insided each plate. I used my old Army entrenching tool to clear the rocks and dirt out from under the Beast to get up under there, plus to ensure the rattlers had not moved in since it has been sitting for 6 months. I used a pointing trowell to dig most of the junk out of the belly area! A lot of my belly plate bolts had not been put in correctly and had come loose and were half bent over, so I had to work them out with Vise Grips and in one case, cut it off with a grinder, then I retapped all the threads. I used new bolts with flat washers and lock washers to put them back on. Somewhere in the history of the loader, the front plate had been lost and a home-made one had been put on. It was bent in half, we used the rippers to raise the loader up and lower the back end of the loader on to the plate to flatten it. Went back on a lot better!
I am hauling the power washer back out this Saturday and we will power wash everything on top again. We will have to change all the fluids in the transmission box and the hydraulics. The hydraulic fluid that came out looked like milk! Just another expense!
Car Quest has been the best for miscelaneous parts (belts, hoses, filters, seals). The nearest Komatsu dealer is 90 miles, so we haven't tried them. For IH specific stuff, we have gone with Chartrand or Traxx or Brown International. Brown is good, but expensive.
Walt came over tonight, and as Willie at Chartrand explained to us, the new shaft will work fine. We put the brake gear on it and measured it every way possible. Just need to get it to a machine shop to have the snap ring grooves cut.
