Cast iron
Hi guys,
The owner of this Russian machine doesn't want sleeves to be installed. He insists on building up the holes with welder and then cut them to the size.
I was through the internet discussions and found two ways for performing the job:
-oversize the hole, then use two layers of steel (S6) wire, then cut the second layer down to pin's size
-use special type of wire, but not quite clear which one
I am afraid of “weld material peeling out when bearings are installed", "You will also get fair under bead cracking", "nearly all cases where a heavy preheat, maintained heat, and post heat isn't done there will be a layer of very very hard carbides where the weld meets the original cast ".
I'm confused. Don't know what to do.
Any advice gratefully accept
