Ray, I've never even seen a 993K in the flesh yet but from what I can see from looking at it on the Cat system it's a bit of a half-breed between the 992K and the 994F. Instead of the box-boom of the 992 it uses a set of regular H-shaped lift arms like a 994, but some of the pins in the bucket control linkage (not sure which ones) are pressed-in cartridge pins like on the latest generation of 992K. I'll see if I can find some more info and e-mail it to you.
Regarding collets I NEVER do what Cat suggest by putting anti-seize both inside & out. I just put it on the inside and they never move - but they DO come out when you want them to. Also worth commenting is that when a collet pin is first assembled and torqued you need to keep beating the bejasus out of the collets until it won't torque any more, then go back once every operating shift thereafter and keep torquing the bolt until it does not move for 2 consecutive days. They always move a bit after first assembly, the only variable is how many days it takes them to stop moving. Then, and only then, do I consider a pin "Tight".
