tool_king
I have used water remover socks that made of plastic with a stainless cable attached to it that you can drop in the taank .You can group several together to help speed up removal . I have some in John Deere skid steer running around right now . They are good for diesel,gasoline ,hydraulics and other oils .I will get the name off them .Now keep in mind they are not going to remove gallons of water .Guys I never thought about the o-ring or seal to be the issue. Come to mind I don’t remember seeing an o-ring when I took the breather off when I changed the oil. Probably be a good idea to purchase both.
What I also found interesting is that the whole new assembly #13 is cheaper than the service kit #16.
I can’t believe I overlooked the seal and o-ring. I’ve looked at the picture tool_king sent 100 times and never realized that those could be the issue
