Hmm... @cosmaar1 that picture is from the inside of the tool box? Mine is always damp or wet in there. I bet I have the same issue... Do I understand properly that you are just going to seal up the entire top of your tank? Hmm, again. I can't imagine a new tank isn't like a billion dollars.
Yes it is. I used to have a tube of grease in the tool box and I figured it was oily because of the grease. A week or so ago I finally was able to clean it out, use degreaser, and get it looking good. I used the machine for about 25 minutes to let it dry out and when I was done, the whole box was wet again. I'm like WTF.
I was working with my dad last week and I had the lid open and noticed oil all over the door. When I looked closely, as he was using the machine and it was building pressure, the bottom of the tool box was bubbling oil.
I do not have the means right now to replace the tank nor do I want to spend another $500 in oil that I just replaced 3 months ago, but I bought high temp, oil resistant silicone and I am going to seal the lid shut so no water can get in. I could care less about using the toolbox, so to me this is the bandaid I am going to use until I am able to cut out the bad areas and replace with new metal.
Attached is a picture I found on the internet of a similar tool box. I am going to run beads of silicone on the inside (red arrows), close the toolbox, then fill in the gaps with more. I will probably leave the drain holes open to allow the oil that seeps out a place to go.
