Any of you guys that work on large heavy equipment in the field, what model of 1” drive pneumatic impact are you using? I run an Ingersoll Rand 3940B2Ti, works great for 90% of what I do at a max output of 2500 ft lb, I have ran into a few places where it’s too long to do the job, one being track frame bolts on a Komatsu PC-1100. I’d like to get the same wrench in a pistol grip for things like that.
I’ve tossed around the idea of buying a 1” cordless, I’ve also considered buying an air regulated wrench (rad or hytorc or similar) Im thinking the regulated wrench will probably serve my purpose the best. Some tight bolts can’t just be cut off with a torch, like large tractor master bolts or track frame bolts. Would be nice for torquing swing transmission bolts on large excavators also.
Used an 1-1/2 dr pnuematic rad gun. After that I didn't want to bother with torque multipliers anymore.
Except maybe track shoe bolts. One fellow I did some work for wanted me to heat the track shoe nuts till red then impact the bolts tight.I like the taking things apart with an impact. I never use then to finish assembly or installation of any component.
Upgraded the HVAC box in the kenworth this morning, long overdue as the factory one was rusted through. Bought the replacement box fully loaded from shoreline truck parts out of Holland, Michigan. It’s all stainless and came with evap, heater core, blower motor, expansion valve, thermostat, and fresh air duct/actuator. Built well, fit right in like it should, and their customer service is excellent. It was expensive, but so is everything else, especially things that last. Glad to support an American company as well.
Believe it or not, even with all that rot, still hands down the best AC in a service truck I’ve ever had. Also sucked a lot of dirt in thoughI've been working on trucks how long? In all my years I have never seen a HVAC box eaten up like that.
So much for the midwest.
We had 1 KW at the feed mill, guy that drove it kept it super clean even under the hood.He started to complain about no heat, hoses were hot, all the controls worked??Got to looking closer at the air box and noticed a big hole where someone had permatexed a piece of something over the extreme rot, the fan was blowing all the heat into the engine compartment. Fabricated a "better cap" for the bottom of the box and it was still working when I quit.I've been working on trucks how long? In all my years I have never seen a HVAC box eaten up like that.
That depends on the design and the requirements of the job. The ones that precast made here had loops of rebar that on the ends that could be pinned, but most of the early jersey barriers we made did not. Also those loops can get damaged in handling and as a result there could be spots in the run that weren’t as well supported. It would be the responsibility of the contractor’s safety person, the inspector, and the job super to make sure the barrier was as safe as it could be. also you play a part in this: ”If you see something, say something”.I thought they were pinned together. At least we did
