Was the 3408 version a 4200 or 4300 I remember seeing a brochure for such a truck somewhere.That is what he told me and one of the reasons he bought it. I found some reference the 4200 was the short hood and could also come with 903 Cummins and I think a V800 whatever that is. I've only ever seen them listed with an 8V-71. Apparently the 903's weren't the best in truck applications but were very popular in 4 articulated wheel drive tractors.
An A model 3406 will as well, or at least mine did when I had my wife pull the truck away from a dock where my doors were toughing the neighboring trailer and I was back there macking sure they didn't catch on each other. It took me a moment or two to figure out what had happened.Yes, but probably quit fast enough to toss part out the side.
Also on a somewhat side note a Detroit can run backwards. I'm not referring to ones set up for that like say some boats that have them run that way to balance out the torque effect from the props.
I mean if an operator lets one stall going up hill and then does not push in the clutch and truck rolls backwards. Seen one do that my first year at quarry back in 1968! Lucky someone got the driver to kill engine fast before lack of oil pressure killed it big time. It was an old standard transmission Euclid haul truck.
At one time (many years ago) I had a 4300 with a 400 cummins and a 4200 8v71. I don't recall the hood being any shorter on the 4200.And you are absolutely correct about that.
Should be glad it's still there-might need it.
Yes,sort ofChecking drainage?
4200 is shorter-I think it's more like 8", early western stars also offered a short hood version.At one time (many years ago) I had a 4300 with a 400 cummins and a 4200 8v71. I don't recall the hood being any shorter on the 4200.
By the way, I like your piece of conveyor belting over the tilt cylinder!Yes,sort of
Thanks sirBy the way, I like your piece of conveyor belting over the tilt cylinder!
I found a reference to being 10" shorter.4200 is shorter-I think it's more like 8", early western stars also offered a short hood version.
In certain types of application we found these worked well to protect blade tilt cylinder rods, and obviously seals because the rods weren't getting dinged so often.By the way, I like your piece of conveyor belting over the tilt cylinder!
Well the one I witnessed had an oil bath filter, but do recall a bit of a mess running down the fender!A Detroit that runs backwards for any more than a few seconds needs a new air filter. I've seen some with filter elements that were mostly burned out and dusted the engine.
I stopped and measured the hood on a 4200 a friend owns against a 4300 he has, with crackedI found a reference to being 10" shorter.
Intercity.Must have been lots of demand to make the short hood models.
