"Whoa ! I thought you meant I could undo the piston cylinders at the bottom and remove the Bolts to the shroud and raise the whole assembly up making sure the shroud clears the fan , of coarse this would be done with a come along attached to the top part of the protective cage that protects you from falling debris . I thought I understood this now he’s confusing me"
That's what Tinkerer is saying, and I agree, you can do this. I would not do it that way. I was trying to answer how the cylinders come off to replace/get repaired, if you need that explained, just ask.
Does the radiator bottom attach to the shroud or something else on the frame, I don't like working under suspended heavy iron, especially with a come along. The radiator and my neck would not take that risk.
IF the radiator will come out, then that's the way I'd do it.
