mcprp
Got it !
Don't give up now !I’m done .
Yeah, excess silicone can break loosed and end up stuck in water jackets and your radiator core tubes. Just because you have a whole tube of silicone doesn't mean you have to use all of it on one gasket.Just don't use too much gasket sealer. I was told by shop too much can cause problems if it gets in the cooling system. Just a thin bead should suffice.
Lol ! What do I have to pull the engine ?
Clean all the crap off of the pump. Then remove the two mounting bolts and slide the pump back enough to get the belts off. The splined shaft may be seized from rust.
Ok , yeah I brought the radiator home to see how much they want to put another core in it . They quoted 800 to a thousand on the phone which seems ridiculous to me but they said bring it in so they can look at it . If not anything else it gives me room to clean everything .Your radiator appears to have seen a tough life ! The tube walls must be getting awfully thin.
Yes, pull it forward until you get a gap big enough to get the belts through it.
The pump does not engage the crankshaft. The pump shaft is inserted into the coupler. That is why I posted the drawing.
Take a close look at how much wear is on the shaft splines while you have it where you can see it.
I have seen some that were on the verge of failure due to wear.
I wish I could actually see the bolts I’m supposed to take out to pull the pump forward . I looked sit pretty close and I stopped because I couldn’t figure it out . Maybe I’ll see better tomorrow . You said there’s two , right ?Ok , yeah I brought the radiator home to see how much they want to put another core in it . They quoted 800 to a thousand on the phone which seems ridiculous to me but they said bring it in so they can look at it . If not anything else it gives me room to clean everything .
these two bolts ?Clean all the crap off of the pump. Then remove the two mounting bolts and slide the pump back enough to get the belts off. The splined shaft may be seized from rust.
