walkerv
Yes mechanical guage reads same as my scanner and vcads. The actual guage in dash is a little low lower it gets . Oil pump is a new reman took it apart and inspected it and measured it prv is with the pump i dismantled that as well and applied a bit of lapping compound to be sure plunger was sealing. Thought for sure the standard rod bearing on a 10 under crank was the culprit. Full speed oil pressure in spec. What i am seeing is psi fluctuations when around half throttle goes 39 psi up to 50 then back down , i am currently triing to get to one of our junker engines to have a look at the oil filter bypass valve in the filter head , my whole problem with this engine is the short block was assembled by someone that no longer wotks here and i cannot find out what all he put into it. I will take a picture of the oil flow diagram when i get a chance i know rods and mains are good for sure . I dont know about cam bearings aux shaft bearings or the idler gear which is also fed oil. To me it sounded kinda noisy in the front cover , i have not been in there yet. Oil pressure is sensor is in the filter head which is first spot the oil goes after leaving pump then it goes straight to the mains and goes put from there . Im almost wondering if my filter head has a crack in it now that im thinking about it . It is a mack etech with flat plate cooler set up if anyone is familer with that arrangment 2004 truck
