The chunks were occasionally jamming it up we think absolutly no metal was found untill we wiggled it then a handful fell out from behind the bearing.Hmmmm, musta been catching a high spot!
Have you tried looking it up under the "as shipped" function? 2-3 spots down from system and components link. That will help narrow it down for you.I will be in the shop bright and early monday morning waterpump started leaking on my way home saturday. Tried making a parts list every waterpump option in sis came up contact dealer only one reman option showwed up as instock so i guess i call my favorite parts guy and get a lesson on parts lookup right quick. If. Anyone wants to mess around on sis cuz they are bored ser no ckm43313 , ar 201-6317 v belt style drive.View attachment 182991
Yeah that got me the contact dealer choice , and in reman search shows no waterpump even though i know it exists.Have you tried looking it up under the "as shipped" function? 2-3 spots down from system and components link. That will help narrow it down for you.
You got the reman number correct . What was the updated clamp for? They had. They the reman on the shelf also when the contact dealer thing showes up i end up talking to my parts guy he needs to show me how that works some evening when i go buy there before he leaves .im glad im hourly doing that pump and tstat and a new water pump belt in a gmc chassis sucks .Well from what I see the original "as shipped" pump was a 120-8402. That appears to have changed to a 365-2134 which in turn went to a 352-2157 which has a Reman number of 20R0586 and a "Classic" number of 4330441. The Reman number shows as $245+core of about $200, Classic $237 and no core.
All that said I'd still run it by your local dealer. Also noticed there was a service bulletin that mentioned an updated clamp that referenced the CKM serial number you might want to have them look up for you.
Not that it will help you but both the Reman and Classic numbers are on the shelf at my local dealer in Syracuse.
Yep i order those got the wrong ones ended up reusing my old ones . New clamp is 2 piece with an inner wrapper like mack used to use.Not a lot of information but here's what came up:
Yeah we have a couple with set up 4 i think not sure if its speced the same as a michigan special but they do have heavy fronts on them , all 4 are tri axle dumpsJust noticed the twin steer Sheppard p/s box on the passenger side. Heavy wagon you have there.
