Wytruckwrench
Mack’s are a different breed.
I overhaul a lot of Mack engines. I have found that the blocks always need line bored, the cranks are always bent. The bearings will show signs of weird wear patterns. Short of tearing them down to the block and crank and sending them to a good machine shop to line bore and straighten the crank, I put them together and run. They will last a fair time, they are tough.
Something else is that they have different oil pumps depending on if they have jakes or dynatard. The oil pumps look the same at a glance. Get ahold of a good mack Parts man and make sure you have the right one. Due to the bends in the crank and mis-alignment of the block, you can’t trust plastigauge. Just some things I have learned over the years.
