Crane operator-it mostly depends on the situation of towing from front or back. I tow mostly from the back but several I've towed from the front also. The later fairings don't
have the issue the older styles had with wind and in windy conditions I just run tie straps around the fairings for support. The sun was going down so this one got towed
from the back, I can run a steady 67/68 towing from the back and they tow better that way also. And yes we have a bunch of DT12 Freightliner auto shifts, and yes pulling
the drive line is a must do, other wise you might buy a $18,000.00 transmission. But the W900 is equipped with everything I need so getting the job done goes fairly easy.
Billing was 38* Drumond was 13* and freezing fog, thick fog. 4th of July and Lookout passes were 27* and light freezing fog. And I was only out of the shop one full day and there's three in the shop.
And I only pull axles on a bad rear drive issue other wise I remove driveline and put air to that trucks system to keep brakes released and bags full.
Super Trucker? I've been called much worse than that.
