Junkyard's work thread.....maybe haha
RZucker
Wherever I end up
Mechanic/welder
Give him time!!
I left a 4 month old chocolate lab in my truck for 20 minutes once. Bugger ate all the coily cords on my 2 way radio and old school hard mount cell phone, chewed up a corner of the dashpad, and gnawed on the shifter handle. Last time I left one in the truck.
My next dog years later was a Heeler, she would lay by the front tire of the truck all day long doing field work, she was funny in the shop, I was torque turning Cat mainbolts and laying on my side on my "queen size" padded creeper and the dog was laying on the pad behind my back. I had her for 18 years as a work helper.
Cheap "old" Geezer
Mine was a Malemute, would decide to get an attitude if left him alone. Ate the 5x5x3" tall wooden knob off a armchair when I had to make a emergency call to the station I worked, decided my VW park brake lever needed more non slip depressions when sitting at a friends house. Decided for my Mother her Rose bushes were mighty tasty, ate them off to the grade from 3' tall thorns and all. Loved Beef knuckles for treats, lasted around two hours before was little to nothing left, could hear the popping from inside the house as he broke them up(raw). His favorite toy, a riding mower tire(dismounted) thrown like a football he would run it down and fetch it back to gnaw on for hours like a massive squeaky toy minus the squeak. Could dig a crater 4'x 3' x 6" deep in what seemed seconds, could NOT locate a spoonful of dirt to refill the holes.
I anxiously await the tale of a boot or pair of britches getting eaten! Would be a Perfect Pup for that!!
StanRUS
Cal
On the way home from work, stopped by market, purchased steak...feel asleep and forgot the steak was on the kitchen counter. Next morning, ops. Okay give the neighbor's shepherd the steak. Neighbors HAVE TO cook the steak before the dog can eat it.
Bumpsteer
Front seat on the Struggle Bus
Mechanical designer
Guess I'm lucky with my 2 dogs, they treat my Suburban like a rolling doghouse.
Had it in the shop the other night, unloading tools. Rear cargo doors open.
The golden retriever was driving me nuts! Following me around, just up my azz.
Finally realized, doors open and he couldn't get in, tools in the way. Opened a side door, problem solved.
Ed
Junkyard
Claremore, OK
Field Mechanic
I unloaded a rig today in a soupy job site. Of course dog wanted out. Tried to keep him out of the mud. Stuck him back in the truck. Put my stuff away and came back to crap all over drivers door and my seat. Couldn’t blame the poor guy.....I’ve done worse myself!
kenh
bonners ferry,id
My current Goldie has a addiction........BAGELS.
If I have hone she will jump up/down, growl and snarl. until I share with her.
Favorite toy is a plastic coffee can, she play soccer with it/
6- 8 cans scattered over about an acre.
Junkyard
Claremore, OK
Field Mechanic
Nothin terribly exciting to report. We have several rigs in KC so I’ll be up here all week getting them taken care of. Major gremlins in the Soilmec. CAN-BUS issues. I have checked every connection, grounds and some sensors. I’m down the the alternator as that’s one code I have in the computer and it is overcharging a bit. There’s also a module on here that shows input from terminal 14.....but it’s not used nor are any near it. It also has a constant active code. 5-7 days from Italy plus a few more from CT to MO.
Never would I have dreamed a drill rig would have WiFi and a mile of Ethernet cable!
62A98143-D501-41DD-9AE0-577E02EDA8D3.jpeg B0DF0A82-069D-4E00-925D-0EC7A3542E4E.jpeg
Junkyard
Claremore, OK
Field Mechanic
To me it’s entirely too complicated but what do I know! Funny thing is all but the generator and AIO.42 codes come and go as they please.....it did it yesterday just sitting there idling while I was looking at the schematic. It’s 100 pages!
Junkyard
Claremore, OK
Field Mechanic
The cabinet that particular module is in seals up well, positive pressure and desicant blocks. I agree that it’s a risky way to do things long term.....this rig has 2315 hours on it.
Camshawn
Langley BC
retired
Junkyard: Have you rebooted the main computer and Ethernet card? This may require removing a fuse or the power. The risk is the program may crash on power off leaving you worse off. We find that this is most often the solution to a lot of industrial electronic devices. Lots of smart devices get confused and need to reload the program from memory in order to work properly. You will probably loose the fault codes so take a picture before you start. Good luck. Cam
Junkyard
Claremore, OK
Field Mechanic
We’ve done all the reboots and resets the tech was willing to walk us through. I decided after today to send out another rig and the factory is sending a tech out to help us get this thing figured out. I sure hope it’s not something stupid simple!!!
Thanks for the tip, I’m sure I’ll have issues in the future.
hvy 1ton
Lawrence, KS
Do you know if any of the code generating bits share a ground? I had 2 abraded wires intermittently backfeeding 12V to the common ground that would cause the same 10-12 codes all at once.
Junkyard
Claremore, OK
Field Mechanic
The insecure mechanic in me is worried factory tech comes and finds something STUPID simple. The rest of me hopes he’s stumped too and we figure it out together. We shall see!
I buttoned up the Watson today. Finished resealing the accessory drive and compressor. Serviced it and discovered it’s got two old weak batteries so they got replaced today as well. Even had flurries today. It’s that time of year!
