Hello dear
I have this dozer CAT year: 1986, model D4H, serial: 08PB00451, série II
We have recently bought this dozer, upon couple hours I noticed the overheating in the transsmision, we have decided to replace the next parts,
3T8316 planetary transmission sn 1CE514-1675 :
6T8687 DISC FRICTION (5)
6Y7965 DISC FRICTION (17)
9P6799 PISTON CLUTCH (1)
3P7019 SEAL METAL (1)
9P7101 PLATE CLUTCH (4)
valve selector and pressure control
9P3041 spring inner (1)
7G4842 spring outter (1)
Control Valve Transmision Hydraulic 8P8984:.
3D2824 Seal o-ring (1)
6Y2349 Connector Special (1)
8M1322 Spring (1)
9S8008 plug o-ring (1)
So after done the service and those parte replaced, we have placed in service and after 30 hours, again the temperature to continue overheating,
And I went to check the oil filter and this was suctioned look like this did any vacum also, I already replaced.
So now I am replacing the pump as well..
8M1322 Spring (1)
