Sounds like the timing is off . I think you'd be better to pin tdc # 1 when number 4 is on rockover with both valves tight.
Timing looks good pin to pin. If your #4 valves are both tight when the pin goes in the flywheel then the cam must be pretty close to right too.
Make sure the rack is opening when you pull the throttle out of shutoff position. You can see the rack shaft in your third picture just above the timing pin hole .
100% sure that the cam is timed correctly?
How fast does an engine need to be turned over to make an injector pop? Can you do it by turning the engine over by hand? It would be nice if you could pull an injector out and confirm that it's popping (with Hatch's cautions) and also make sure that it happens around TDC on the proper stroke. Can you put something down the injector hole to see where the piston is at when the injector fires?
Dodge that crap didn't come out of the old muffler by chance, Ive seen that happen
I think that the engine needs to be spun at 500 rpm in order to pop injectors and start. You know, instead of either, soak a rag in gasoline, ring it out and drape it in the intake path but secure it to keep it from being sucked in if it does start.
Did the block get bored and sleeved back standard or bored oversized for oversized pistons
Yair . . . lantraxco.
That's interesting, there was a thread about this a while back where you or some other member mentioned WD-40.
There may be different solvents used in the product over here as I tried it on a four cylinder "Standard" diesel in a Fergi and it didn't want to know about it . . . then tried it with the gasoline rag (which I have used for over fifty years) and it lit up right away.
Cheers.
Cheers.
You should see the slotted part of the rack move a bit when you move the throttle from the shutoff position.
200 rpm on the starter should get it firing.
