alrman
- Joined
- Jun 20, 2009
- Messages
- 3,310
- Location
- QLD Australia
- Occupation
- Diesel Fitter;Small Business Owner;Cleaner
The "front" cover is at the front of the transmission - hence the need to remove it for repairs.
It weighs over 1 ton; the machine needs to be raised & the transmission is lowered out from under the machine towards the rear.
The transmission needs to be on it's back with the front cover facing skywards for most of the repair procedure.
There is some special tooling required to overhaul these. Everything can be made, as with anything mechanical, there is a great deal of things to get wrong during reassembly.
Exchange transmissions, if you could find one which I doubt, will cost 2-3 times than what the machine is worth.
First thing you need to do is the simple pressure test I described above, take particular note of where the pressure loss / delays are & let us know.
As much as I like to help people, I don't really fancy talking you through a transmission rebuild over the internet.....
- Pinion depth is critical - tool required
- Clutch packs need to be pressure tested before installation - tool required
- Shaft end floats need to be measured - tool required
