atgreene said:
back into position. I say the entire set-up is junk, as anything rated for 14000 lb carrying capacity damn sure ought to load an 8000 lb machine on relatively flat terain without looking like a cheap imatation of an equipment trailer.
A few things come to mind...
#1 If I remember corectly you wanted them to derate the trailer to 9,999 Lbs, for DOT reasons. Posiably they built you a trailer 4 9,999 lbs..... trailer weight - 8K machine and you might be over a few 100 lbs now and maybe this is why it is bending,
#2 in looking at the photo of the back side, I believe they have built the trailer wrongm the last bit of tapper on the trailer should be cut out from the bottom side, not the top side. the way it is built now almost 100% of the weight when loading and unloading is on the very edge of the tip of the ramp. If the cutout was from the botttom side, most of the time the presuere would be spread out on the cut out portion instead of just the tip.
#3 your ramp is too narow at the end, it looks like your trailer was built for a show car, or other light weight stuff that can't get over a small hump.
#4 as much as its wrong, "Tail only, seems like the rest is corected" can you live with it? it does funtion as a trailer, yes it looks like crap for the tail to have a bow, but its a equip trailer, not a show car trailer, a little bit of mud, a few more scratches and you wont see it anymore. Not to mention your making money with it. I would rather have them discount it then mess around and lose money on work.
Good luck
David
