Orchard Ex
Super Moderator
My ramps are built with the point down (except for the first rung - it's up). Lots of ramps that I see are built that way. I think it is to make climbing up easier/smoother for wheeled equipment like a skid steer. If the rung points are up and the tires are small and narrow, you are climbing over a series of wheel chocks, (the holes between the top of the rungs are wider and the tire "falls" in between). Most of the guys around here running lots of tracked gear end up with wood planked ramps or tilt trailers. Having the angle point up like nobull1's will let the grouser slip as the track comes around the sprocket and shouldn't bend it.
LT - you'll have to explain to me how a piece of angle iron welded between two runners is "stronger" turned point up. I've never seen angle stock strength qualified by the position it is welded in.
