Try the wax trick, on the stuck threads. Heat to about 500ºF, with a propane or butane torch, while checking with IR thermometer. shut off torch, and grab a hunk of bees-wax, and place against hot metal, as close as possible, and let the wax wick into joint area (like you would solder a pipe). Also have had good luck with left handed drill bits, though I didn't need to do this, when I pulled the solenoid valve on my perkopiller, a coupla years ago...
Another thing that helps, with the wax trick, is to tighten, just a little, before you try to loosen. Don't know why, but it has, for me...
