toomanyedwards
Hi all,
I'm attempting to get a Cat 3013C that's been sitting for ~5 years running again. I've got it turning over, but won't start. Looking through the forums seems like a common issue. So far I've:
1) Drained fuel tanks and filled with fresh fuel with seafoam
2) Replaced batteries and a bad starter
3) Replaced glow plugs and verified circuit and plugs
4) Primed fuel filter and fuel pump
My guess at this point is potentially a fuel delivery issue, but I get fuel coming out of the fuel filter vent and fuel pump banjo as expected when priming so that side looks good. I hear the fuel solenoid click when I turn the key to run so I think that's good. What's the best way to verify I have good pressure on the high side of the fuel pump? I read the old thread: https://www.heavyequipmentforums.co...rkins-cat-3cyl-engine-wont-start.66080/page-2 and someone suggested pulling an injector to check if it's spraying. Makes sense to me, but I'm not sure how to just pull one injector on this engine since it looks like all hard lines from the fuel pump to the injectors. Any thoughts or ideas for next steps here are greatly appreciated!
