funwithfuel
That is a common problem. I asked early on about the fuel water separator. If it's the one with the glass bowl, they're prone to air intrusion. The rubber gets dry rot and cracks. The little plastic drain cock gets wonky too. And the seal for the screw that runs the center. The pressure sounds good. As long as its liquid fuel and not foamed.
Can you run an alternate fuel source to the lift pump?
