A25c won't accelerate
Discussion in 'Shop Talk' started by Dakotab19, Jun 10, 2019.
  1. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,816
    Master Inj.Pump rebuilder
    Sunny South Carolina
    The timing off-set is built into the pump.. SO..
    when the PUMP POINTER is centered in the window.. the ENGINE will be at TDC..
    The aneroid does have a star wheel but the access is under the TOP cover or thru a SIDE cover..
    Those engines are always under powered & I always turned them up 10% AFTER I got done TURNING THEM UP to spec..
    They were like "race cars" when they gottm back.. Lol
  2. Dakotab19
    Dakotab19 Active Member
    Jun 10, 2019
    36
    Michigan
    When you say pumps pointer where is that on the front of the intermediate shaft going to the pump or through the hex plug on the side of the pump, or am I just missing it completely? 15602918866297092390616357743371.jpg
  3. thepumpguysc
    Mar 18, 2010
    4,816
    Its that 8mm plug below & to the right of the return line.. below the shut-off lever.
    Its gonna be TIGHT.. rap it a couple times w/ a hammer & brass drift 1st.
    How are the rpm's?? almost every one I've worked on is way low, on max no-load rpm's.. {& fuel}
  4. Dakotab19
    Jun 10, 2019
    36
    Michigan
    The rpms seem to reach full throttle (around 2500).
  5. Dakotab19
    Jun 10, 2019
    36
    Michigan
    Is there supposed to be oil in this section of the pump?
  6. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    1,989
    Mechanic
    Will county Illinois
    Yes, oil in that cavity.
  7. Dakotab19
    Jun 10, 2019
    36
    Michigan
    How do you see in the pointer do you have to remove the coolant pipe?
  8. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    well you're really supposed to have an AB light. its a tool you screw in in place of the plug and has two sensor probes that wait to "feel" the pointer coming by. When both A&B light up you are dead nuts on. In the interest of down n dirty you could just watch for it with a mirror and light.
  9. Dakotab19
    Jun 10, 2019
    36
    Michigan
    What will the pointer look like when it comes by?
  10. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    A pointy arm pointing right at the window
    Mother Deuce, Vetech63 and mg2361 like this.
  11. Dakotab19
    Jun 10, 2019
    36
    Michigan
    Is there a specific spot to bar the engine over with or are you just supposed to use the front of the crank?
  12. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    On the exhaust side of the answer in the bell housing front face there should be a 10 plug with I believe a 22 or 24 mm recessed hex . One of those is in line with the edge of the fly wheel with an engine turning tool or pinion you can turn the engine over easily from their otherwise you are stuck trying to turn it from the front of the crank damper. Some of the older machines even had a whole then aligned with the crank bolt so that you could put a long extension in there and turn it from outside the frame
  13. thepumpguysc
    Mar 18, 2010
    4,816
    Yup, special turning tool from access plug in flywheel hsg.
    OR.. crank
    IF U WANNA KNOW when your GETTING CLOSE, remove the hex head plug up towards the drive on the side of injection pump{12mm?}.. When it STARTS TO RISE, your on #1 compression stroke & start looking in the timing hole for the pointer..
    mg2361, Vetech63 and funwithfuel like this.
  14. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,638
    Oklahoma
    You guys are gooooood!!!!
    Mother Deuce, mg2361 and funwithfuel like this.
  15. Dakotab19
    Jun 10, 2019
    36
    Michigan
  16. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    Yes that is the little fella you're looking for now what is the pointer showing on your flywheel timing degrees
  17. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    You can jump in any time you know
  18. Dakotab19
    Jun 10, 2019
    36
    Michigan
    Timing is set at 8 degree s which is what's specified on the valve cover.
    funwithfuel likes this.
  19. Vetech63
    Aug 10, 2016
    1,638
    Oklahoma
    Oh hell, I'm enjoying the ride-along!!
    sfrs4 and funwithfuel like this.
  20. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    OK now you've learned something valuable and you verified that your timing is correct . next up is put everything back together let's fire it up and see will kind of boost your building. Find A pipe plug or nipple or something between the intake manifold and the turbocharger were you can gauge boost pressure while you throttle up. It would really be nice if you could put a 100 pound gauge on your fuel supply system after the lift pump also to verify that you have adequate fuel pressure to your injection pump.
    mg2361 and Vetech63 like this.
