A25c won't accelerate
Discussion in 'Shop Talk' started by Dakotab19, Jun 10, 2019.
  1. Dakotab19
    Dakotab19 Active Member
    Jun 10, 2019
    36
    Michigan
    Hi all new to the forum here and looking for info on an A25C. The problem I'm having is that when you put the truck in gear it won't really rev up and go anywhere. If you just move it around at idle it will move fine, but if you try to accelerate it just bogs the motor down and has no power.
    The Motor was rebuilt when we got the truck and seems to run good, other than revieg up a bit slow from idle. This kind of leads me to believe it's something with the trans, like possibly the retarder being stuck on (if that's possible)
    I don't know if anyone here has any experience with this situation, but even some direction as to a possible cause would be helpful.
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    1,989
    Mechanic
    Will county Illinois
    Got fuel, how bout boost?
  3. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,805
    Master Inj.Pump rebuilder
    Sunny South Carolina
    What does in do in Neutral.. rev normal or bog.?? THAT'LL tell u if u have a fuel or trans problem..
    IF it revs normal, chances are its trans.. IF it bogs & is slow to accelerate its fuel..
  4. Dakotab19
    Jun 10, 2019
    36
    Michigan
    Seems to be getting great fuel pressure haven't checked for boost yet. Is it possible for the exhaust retarder to get stuck closed on these?
  5. Dakotab19
    Jun 10, 2019
    36
    Michigan
    In neutral it revs up but from idle it's slow if you rev it in stages it acts normal. I didn't know if that was normal for these motors or if there was a problem, because other than slow reving from idle it seems to run really good, and it starts really easy.
  6. thepumpguysc
    Mar 18, 2010
    4,805
    Check the over-flow valve on the inj. pump.. they come loose internally all the time.
    Take off the return line banjo bolt & w/ a screwdriver, reach in to the center of the ofl vlv & see if the screw is loose or tight.. IF its tight, leave it alone..
  7. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,637
    Oklahoma
    What engine is it?
  8. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    Does it sound like the retarder is stuck on? It's a very distinct sound.
    Has it been like this since rebuilt? Are any of your pumps getting hot?
  9. Dakotab19
    Jun 10, 2019
    36
    Michigan
    It doesn't have the distinct whine of an exhaust brake, but I didnt know how these systems would sound.
    I believe it has been this way since the rebuild, but I'm unsure how it acted before.
    When you say pumps do you mean the hydraulic pumps on the trans?
  10. Dakotab19
    Jun 10, 2019
    36
    Michigan
    The engine is a Volvo TD73KCE
  11. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    Yes, if the pumps are loading by a false load sense signal it'll bog the engine. The engine should be able to power through with sufficient fuel n boost. Now if you're hearing a loud rushing noise as opposed to a loud hissing noise, you may be looking for a ruptured boost hose joint to or from the cooler. What kind of smoke you seeing?
  12. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    By your description, I'm leaning toward retarded injection timing
  13. Dakotab19
    Jun 10, 2019
    36
    Michigan
    I am not really getting any smoke it will just puff out a little light grey smoke occasionally.
  14. Dakotab19
    Jun 10, 2019
    36
    Michigan
    I checked the valve and it was tight any other suggestions?
  15. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    Fuel water separator bowl tight?
  16. Dakotab19
    Jun 10, 2019
    36
    Michigan
    With retarded timing would it still start good?
  17. Dakotab19
    Jun 10, 2019
    36
    Michigan
    Yeah its tight and looked clean.
    Do these engines have an aneroid adjustment, now that I've been thinking about it isn't it a little wierd I'm not getting any smoke at all?
  18. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    Yes, low fuel pressure = white smoke, low boost = black smoke. Little whisp of grey usually indicates ok.
    Does the engine sound like its laboring to climb up in rpm? If not, I'd see what I could do about confirming pump timing.
  19. Dakotab19
    Jun 10, 2019
    36
    Michigan
    It does seem to labor a bit when climbing past 1500 rpm, but not a ton.
    What's the best way to confirm timing on these motors?
  20. funwithfuel
    Mar 7, 2017
    1,989
    Mechanic
    IIRC timing window on flywheel housing . Take an 8mm grind a point onto it and screw into 3rd hole. Open pointer cover on pump. I do not know what spec is. It may be on engine ID tag. When pointer is centered in window, timing should point at desired degrees
