funwithfuel
8* before or after? Gotta be sure.
What do you mean before or after, before or after the 8th degree mark on the flywheel?8* before or after? Gotta be sure.
TDC before or after top dead center.What do you mean before or after, before or after the 8th degree mark on the flywheel?
Maybe not actually hit it but further forward than in pictureSo the shut off lever should be able to go forward far enough to hit the spacer on the return line?
I did I just thought it was built into the pump and there was a spacer after it, but yeah it was tight.The "spacer" IS the overflow valve.. {I thought u checked it.??}
BeforeTDC before or after top dead center.
The shut off lever goes all the way forward and stops itself before the cable does.Just unhook the cable & SEE if it goes forward & hits the ovflo vlv..
They mighta lost the woodruff key & clamped the lever down to the shaft.??
I'v seen THAT about a bazillion x..
That key is T I N Y...
Yep and the s/o lever goes all the way forward. When you say full load rpm does that mean no load (neutral/ not driving) full throttle, or is that when your really working it hard?Its usually 14-17psi minimum at full load rpm..
DID U UNHOOK the shut off cable.??
