windscreen or windshield..?
Thanks Metalman. I'll take a look at your post . I have priced all the a fairly comprehensive parts list at Offroad but don't want to purchase more than I need to,Here is a thread of when I did a replacement of the recoil springs, fixed up the pilot & rebult the adjuster on my old 941 loader. If I remember correctly, I think the hyd adjuster has the same parts on the 941 & 955. Spring will be different though.
https://www.heavyequipmentforums.com/threads/941-spring-track-recoil-spring-install.60148/
I replaced my springs but didn't chain them. Cut them in place and all was good without issues. Did cut mine more then needed, but I din't want any chance of tension remaining
Thanks Alldodge, Great pic! I have at least 2 coils that are broke and I actually found a 4" piece on the ground after the last time I moved it! I will probably go ahead and chain them because one is bowed up as you can see in my pic earlier in this thread and don't want any unexpected issues to deal with. I priced a bunch of the parts from Offroad but they did not have the main bolt and nuts that hold the recoil spring. I'll check again before I make the purchase. The pilots were $86 each but do not know how to tell how worn they are or whether or not I actually need new ones. I appreciate any advice for what to look for. Thanks again for replying. It's been a while since I posted here.
https://www.heavyequipmentforums.co...sprocket-springs-and-other-stuff.55139/page-3
