650J john deere calibration problem
JSLtrucking
Mt sterling ky
I have a 2006 650 J that needed to be calibrated, at the end of the first stage of calibration it throws a F359 code. This code is tied to the DExcelerator pedal, according to the diagnostics the low settings on the pedal may be just a little out of range. This may or may not be why it's throwing the code I have tried to adjust the range of the pedal but I get no change on the number in the diagnostics. Any help to get this code fixed or help me get out of calibration mode would be much appreciated!
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF JSL;)!
Machine serial number?
What voltage did you set the pedal to? Where did you get the procedure for calibration? Is it the correct one?
