darinray
Charter Member
1992 according to my book.
Welcome aboard rangerfreak:drinkup , I'm not a Komatsu expert but there are a few guys here that do qualify. So fire away and someone will probly answer all your questions.
I had a seal blow on one of my blade angle cylinders today, and one of my lift cylinders has a leaking seal. Where is the best place to find the seals and is this something I can do myself without any special tooling? I've never rebuilt any cylinders before, and advice?
Can anyone please tell me what the bearing number is for a final drive on a
D20P5 is. I have called everywhere and nobody can tell me. Mine is wore off so I can't read them.:Banghead
I have a d20 that is leaking hydraulic oil out of the top of the blade control valve (the up / down / tilt) and it's getting to the point it is hard to feed. It looks like an O ring should fix it, but I can't get the rod(?) out of the valve body. Does anyone have any suggestions?:beatsme
What machine do you have? D20 dash what? There are seals that will need replacing to fix the problem and am not real sure why you can't get the spool out of the valve body. Did you take the bottom cups off and remove these pieces? By rights you don't need to take the spool out of the body to change the lower and upper seals... you just need to remove the linkages on top and disconnect the spring below.
Darin
What bearing are you talking about? Do you have a part number from Komatsu?
Darin
It is a d20-6. I've taken the linkage and a cap type thing loose from the top. I haven't taken anything off of the bottom. What is the spool? Is that the piece that connects to the lever? How to get the spring out?
The one right behind the sprocket. The part number one place gave me is 06030-22215. I assume this is the part number, I told them I couldn't read mine off of the part and I don't have a manual to it. The bearing company I called said they could cross refference if I could get the number off the bearing.
Hi I am located in Queensland Australia and need to source repair, part and operator manuals for my D21PL-7E, can you help? also I have to say what a great help you are to all the guys on this thread, I have read all the posts and gained a lot of knowlege just reading the posts, well doneOh I see. Yeah that one is expensive but I guess what isn't. Sorry to say I don't have the number off that one. With the cost of these final drives and you want to be sure you get teh exact replacement brg sometimes is easiest to just order it from the dealer (Komatsu). If you find out a replacement one do share here. Good luck
Darin
Hello Richard,
Yes I have those manuals so contact me through my link below so we can talk more.
Darin
