Wylie5
- Joined
- Dec 12, 2009
- Messages
- 34
- Location
- Euroa, Victoria, Australia.
- Occupation
- Weed Control Contractor
Re:Grouser Relugging
Hi Danny B,
You could use re-o-bar instead of key way bar, as the concreters re-o-bar is the same steel martrial, but at a much cheeper cost in Austustalia than key way bar, just an idear for you. And is easy to buy in long lengths & cut to size also welding, as it is round so you can get good penatration when welding, as if you were to use the Keywar bar you would have to grind an edge on both side to get a good weld, You probly need to weld the keyway bar/re-o-bar on a bit sooner thou.
Cheers Wheelybin.
Hi Danny B,
Cheers Wheelybin.
I need to get more traction. I can tell my D21 has more push than I can get to the ground. I'll try to post a picture to show what I think my problem is. The flat plates on the track are approx 1 inch. My son and a friend on his suggested I weld some 1 inch key stock to the flat plates. Any comments on that idea or other options would be appreciated.
