Have a komatsu D21 p-7 .Wont steer going one way, friend of mine tried to adjust linkage under floor boards. Called komatsu they said he shouldnt have touched linkage . Want to readjust steering brake and readjust linkage back to where it should be. Any thoughts would be appreciated Thanks
so my d20p was working great then disaster... stuck in nuetral no way to find gears any one have this problem and what it take to fix?
Hello Richard,
Yes I have those manuals so contact me through my link below so we can talk more.
Darin
What exactly happen? Was it all of a sudden or gradual? Are gears just grinding? Kinda up in the air right now so need more info.
Darin
Rutro.... Nope didn't get one from you. What email address did you send it to?
Darin
Welcome aboard rangerfreak:drinkup , I'm not a Komatsu expert but there are a few guys here that do qualify. So fire away and someone will probly answer all your questions.
all of the sudden no noise or grinding i was just going from forward to reverse .wont shift into any gear cant even get a grind. i am locked in nuetral the shift lever has side to side play but wont go forward or back to engage any gears..
what your serial # i have a book for 75001 and upI have a D21P-6 and I am looking for the part number and availability of a few things. One is the clutch pedal return spring. It is mounted at the end of the clutch cable and is secured to the side of the transmission. This is the spring that gives your clutch pedal its springy feel. The other one is a rubber bushing/elastomeric that is located at the end of the left angle blade cylinder. Right where the tilt cylinder and the angle cylinder mount there is a rubber bushing on the top and bottom of each cylinder end to prevent metal to metal contact. It appears that all the cylinders have this where they attach to the blade. Any help is appreciatied
