Working on video upload
Check out video on YouTube titled “Takeuchi TL130 charge pressure”I’ll get a video of it but don’t think I can upload it to this thread
Check out video on YouTube titled “Takeuchi TL130 charge pressure”You can, but you would have to upload it to YouTube first.
That seems normal when looking at tl140 specs. I'd Imagine the 130 is same.OK, somewhat of a correction. Changed gauge and got charge pressure of 240 at idle and 260 at high idle. Then pressure dropped to about 110 when joystick is moved
Yes. All filters and fluids have been changed.In all reality, both pumps and motors are suspect (worn excessively).
The next step I'd take is measuring each motor's case drain, at rest and in motion.
They should be the same volume at the same time interval.
Without looking back through all the pages, were the filters changed AND cut open and examined?
With same setup im my Case 1845C machines, I've never had any luck changing a just a drive motor when chasing a lazy drive.
That's not good. That's quite a bit of metal. Looks like you got some tearing down to do.View attachment 254913 Negative, but tank strainer looked like it had brass shavings on it.
Amazing - 5 pages into the thread and only now are we seeing this photo.?View attachment 254913 Negative, but tank strainer looked like it had brass shavings on it.
I kinda thought that, but i was keeping the faith.The filters did’nt look as bad as that strainer on visual inspection. LOL I’ve had so many threads on this and i included the pic of that strainer about a year ago. Luckily i kept the pic to show it again. If I could just pin point it the problem, i could fix it. I’ll keep tryingAmazing - 5 pages into the thread and only now are we seeing this photo.?
It would be surprising if the pumps could even suck oil through a strainer in that state. Lord knows what the filter was like.
Something, maybe more than one thing, in that system is fcuked right royally..........IMHO.
If the parking brake was not releasing, would that effect both sides?Because of the shared hydraulic oil, everything in the hydrostat side needs torn down and evaluated. And, the whole system needs cleaned.
After further review, it looks like i have the correct pressure coming out of the HST pump. When engaging the left drive, the engine loads and starts to bogg down like its under a heavy load but no left drive motor movement. Could it be a failure of the parking brake to release?Maybe start with the pumps. They are easier to take out than drives. Then open them up and look.
After further review, it looks like i have the correct pressure coming out of the HST pump.Because of the shared hydraulic oil, everything in the hydrostat side needs torn down and evaluated. And, the whole system needs cleaned.
As far as I'm aware, the brakes automatically release with the hydraulic pressure. Have you inspected the final drives? Changed the oil in them? Just to see that the gears are ok and not locked up?After further review, it looks like i have the correct pressure coming out of the HST pump.
That’s my next chore. The right drive is good but It just seems like that left drive is locked up and wont release. I’d like to inspect it without removing it completely if possible.As far as I'm aware, the brakes automatically release with the hydraulic pressure. Have you inspected the final drives? Changed the oil in them? Just to see that the gears are ok and not locked up?
