So I'm A idiot! Hydraulic fluid?
Bls repair
S E Pa
Equipment operator,mechanic
Just make sure the specs are the same as what is called for
Tinkerer
From red power forums --->
"I dug out my Hough 30 books.You engine is a G263 IH engine. Hyd system calls for 10W motor oil and in severe service it should be 10W30 motor oil. Your brakes....front wheels adj thru slots at about 7 & 1 o'clock on backing plate.My manual shows a "star" adjusting wheel.The rear adj with cams located about 2 & 10 o'clock.Hopes this helps."
BillHoughH30G
Lucerne Valley, California
Thank you!
You gave me a starting point.
