So I'm A idiot! Hydraulic fluid?
Discussion in 'Tractor/Loader/Backhoes' started by BillHoughH30G, Feb 13, 2020.
  1. BillHoughH30G
    BillHoughH30G Active Member
    Feb 10, 2020
    29
    Lucerne Valley, California
    Hough H30 Payloader... Does it matter what hydraulic fluid I put in? Can I just grab some from AutoZone?
  2. petepilot
    petepilot Senior Member
    Jul 7, 2018
    902
    central shenandoah valley va,
    any good brand hyd oil should work fine
  3. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    1,103
    Equipment operator,mechanic
    S E Pa
    Just make sure the specs are the same as what is called for
  4. BillHoughH30G
    Feb 10, 2020
    29
    Well... Not sure about the specs since I can't find any on the tractor.
    (H30G Diesel seems no one has heard of it...)
    Figured just saying h30 gives you guys an idea what I have.
  5. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,306
    On A Riverbank in IL. USA
    From red power forums --->
    "I dug out my Hough 30 books.You engine is a G263 IH engine. Hyd system calls for 10W motor oil and in severe service it should be 10W30 motor oil. Your brakes....front wheels adj thru slots at about 7 & 1 o'clock on backing plate.My manual shows a "star" adjusting wheel.The rear adj with cams located about 2 & 10 o'clock.Hopes this helps."
    RZucker likes this.
  6. BillHoughH30G
    Feb 10, 2020
    29
    Thank you!
    You gave me a starting point.
  7. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,369
    Service Manager
    Knoxville TN
    It was common or older machines to spec motor oil for hydraulic systems, typically 10W. Cat and Kommie did the same on their vintage machines.
    Ronsii, old-iron-habit and RZucker like this.
  8. John C.
    John C. Senior Member
    Jun 12, 2007
    7,124
    Those old dog machines had gear pumps and didn't care much what you ran in them.
    Tinkerer and Delmer like this.
  9. willie59
    Dec 21, 2008
    12,369
    Service Manager
    Knoxville TN
    You got that right John C. Gear pumps, open center valves, no hydrostat or load sensing systems, you could pour Wesson oil in those old rigs and make it work in a pinch.
    John C. and petepilot like this.
