Craft & KSSS where do you use the blowers with the high chute the most? Do you have commercial contracts or do you hire out to municipalities? How is the production rate loading trucks vs. a wheel loader? I am considering upgrading my low flow skid and blower to high flow unit. Any feedback would be appreciated. Thanks
I hire out to large residential and small municipalities. I normally run the smaller chute except when loading trucks. I usually can load a typical tandem truck in about 7 minutes. The colder the weather the better when blowing. You will want all the flow you can get out of whatever machine you chose. The graders make a windrow (which compacts the snow, not ideal) and I blow the snow into a truck. I would get as wide a blower as you have machine for. Mine is 85" which is as wide as I found. You get less spill off the edges that way. I think the open chute on Crafts would be better for loading trucks, no chance or much less chance of plugging. Mine will plug if you push it too hard when its warmer out. Be sure when you select a skid steer get the control handles that will allow the blower to be plugged into the electrical connection and allow chute operation from the control handles. This prevents having to have a separate control handle mounted somewhere in the machine to operate the chute direction and spout elevation. When loading trucks your constantly changing the angle of the spout or chute it seems. It would be a major PINA to have to fiddle with another control handle for those functions. When your running the blower at full capacity they use fuel.
As far as advantages over a wheel loader, the biggest advantage is you can pickup the snow without worrying about backing into someone and taking up the whole road in the process. I found positioning the truck just in front of the blower works the best. I shoot over the tailgate of the dump truck. Takes some time to get on to.
