JWM : No not hurt performance, hurt the hyd motor .... The gpm of the smaller disp motors may not handle the extra gpm output of 23gpm of the skid-steer for extended periods, those 6.2 cu.in motors are rated for maybe only 20gpm max (continious duty) when you try to jam the extra gpm of the machine through the motors they rev too high, so if you throttle back a couple hundred rpm the gpm will also drop... (boy what a mouthfull).... anyways thats where the hand held tach comes into play .... the hyd formula I used is the one used to calculate rpm of the hyd motor ... so if they (eaton) say that the max gpm is 20gpm for that 2000 series motor you multiply that 20gpm by 231= 4620 (don't ask me what the 231 is for, ask a hyd engineer, its in the book) ... then you divide that number by the given disp of the motor which was 6.2cu.in = 745rpm but that is @100% (I guess that is when everything is perfect, nothing is, eg: a gas engine may have a flywheel rated hp of 300hp, but you have drive train loss of 15-20%, 45-60hp lost = 240hp at the rear wheels) ... so ... 745rpm x 80% = 596rpm actual working rpm .... again this is where the tach comes in ... I checked my BC which has 37gpm on hi-flow, the formula was bang on at WOT but as soon as the blower started to work the diesel rpm drops (maybe only 200rpm, so I ran the diesel 200rpm less than WOT and checked the fan shaft rpm (no-load) .... thats why I started to play with the gearing to get the fan to spin slightly faster with my 37gpm output .... the 6000 series motors I have are rated for a max 40-50 gpm (depends who you listen to) if you do the math for the higher gpm the fan will be spinning faster, so I played with the calculator and found that if I changed the sprocket up to the 20T it gave me the shaft rpm I was seeking ...... The diff was the casting distance of the snow... like in my case I have a contract that I push/scrape all the snow to a common point in the parking lot (too many cars, p/u's, windows, and people walking around, its a 24/7 Coffee/
donut shop) I then put the blower on and throw it up and over a conc block wall, the further I can throw it the better, gives more room for a whole winters stock-piling .... when I changed the gearing ratio it gave me an extra 15-20'.
The point I was making in the earlier post was that you can fine tune the blower to match your job needs (to a point)..... I have the Hp and torque to drive the bigger blower on my BC, but in the case of your 7422-1 and if its just for personal use, you don't have to fork out the extra coin for motors better matched to your skid .... a great deal at first can make it into a not so great deal in a hurry.
The module acts like a balancer between the fan and auger and as they say in the manual if the fan stalls turn the screw one way ... if the auger stalls too easy turn it the other way, till you have it that the auger will stall just slighty before the fan to prevent shute clogging ...... its a bit of farting around, an extra set of eyes help make it easier.
The best rpm is dictated by the torque of the hyd motor, you have the hyd flow and psi just not a higher torque hyd motor.... like trying to take an under powered truck up a hill in overdrive ... sooner or later you have to gear down ... as I also posted before the older smaller blower I have blows snow like crazy, BUT you can't overload it the hp/torque is way less than the big boy .... just gotta keep that fan spinning as fast as you can to throw effectively.... If I had to guess I'd be playing with the module.... sounds to me as if the fan is stalling out too soon .... gotta start some where.
I hope this kinda cleared up your grey areas .... I have been playing with this stuff for a few years to come up with simple answers that might work .... gotta be able to help yourself if you don't have the FAT wallet ... cheers again
