packratc
Thanks for gettting back to me, Alrman. I reviewed post #46. I replaced the bronze bushing and all the seals. Did not notice a groove worn by the seal. I didn't inspect every hole in the converter for cracks. If there was/is one it wasn't readily apparent. So I'll stick with the hytrans fluid is your advice? As to the engine over heating; No, never had a problem before but had not run it for such long periods making it work pretty hard. Incidently, when it's over heated, the hoe has been stationary and the backhoe was being used for digging. The engine was at 3/4 throttle or above. As my hoe does not have a neutral, the manual transmission has to be in neutral when using only the hoe. I know that the torque converter turns all the time. Are you suggesting that the shuttle is over heating and causing the engine to everheat as they're both cooled by the radiator. Or, are you suggestioning that the engine is overheating and causing the radiator to over heat the hydrauic fluid? You know, when you put in new hy trans it's about 20 to 30 weight. When I check it after it's been running it's 10 weight or probably thinner. Does everyone's fluid thin out with the use and heat? What about adding STP or another thickening high-grade oil? I know this would make it take longer to get into gear when you first start it on a cold morning. Back to the other: Are you also saying that if there's too much fluid in the bellhousing that the continual "sloshing" of it by the outside of the torque converter over heats the fluid? Thanks for your continual input. I'm always learning. I'm always learning new cuss words, that is. Packratc
