Well, the hoe is back on & we've dug a couple of days. Still leaking around the starter & maybe the rear oil pan bolts. Ordered starter gasket & will put it on this week. Still think that the torque tube is way over full. Take the dipstick out while it's' running & fluid goes everywhere. Checks several inches above the mark. fluid is so clear it's hard to see. Motor oil is the same clearness. Hoe is leaking everywhere. I'll get them one at a time. I put the 2 ft bucket on it and it digs easily & with plenty of power full of wet soil & mud. Have not out floorboard on the right so the foot pedal is not in place. I'm lacking another spring on one barke pedal & they need to be readjusted so the clutch will go in with brake application. Chic has habit of using clutch all the time. Shuttle works good except Friday it began not going into reverse quickly. Had more & more hesitation & the required reving up of engine. It kicks in & pushes well. Think I need to check all adjustments on brakes, clutch, & accelerator. For the first time the engine over heated. Go up to 250 degrees. Let it set & idle & it came back down. It had kicked out some water so I replenished it with 1/2 gal. antifreeze. Am somewhat confused about operating temperature of shuttle fluid. When hot you can't hold on to the dipstick to check fluid level. Can almost hold your hand on the radiator & lines to cooler but the fluid itself is pretty hot. I'm wondering if I should change the shuttle filter again. Remember I've had this thing apart 3 times. Ran it in & out of pond for 2-3 hrs and it started running rough, sort of cycling up & down. Put in new fuel filters the next day ($23) & that solved that. I had thought the tank was pretty clean but I've found water in the diesel fuel and shaking the machine up pretty good probably loosens things up. I'll use it some today or tommorow & see how shuttle is when it's not warmed up to too hot. I'll put foot accelerator & add fluid to loader. I would advise you all to buy stock in hydraulic fluid until I get all these leaks stopped. The dipper cylinder wiper started leaking Friday. From where I've been, leaking cylinders are like changing diapers to a new parent with twins. It's just something you do. This is/was sort of a disjointed dialogue. I welcome comments, suggestions, prayers, or donations. It's a good thing I just fool with these things for the fun of it. I can't afford to go bankrupt.
Packratc
