Readying for the KW
And I was correct, up at 5, coolest part of morning, 74 shown temp, feels like 80, humid enough my shop is sweating on all the tin surfaces and dripping off the gutter skins. My own glasses fogged over soon as stepped outside and a Haze hangs across the valley. MAYBE Wednesday, looks to be a cool front stirring rains tonight, tomorrow and Tuesday with a temp drop of close to ten degrees on lows Wed, Th, Fri. Will shoot for Wednesday maybe Thursday.
crane operator
sw missouri
Well that's it then, its time for A/C in the shop. The weather spirits have foretold it and it must be done.
Get to digging under that mattress and let some of that old money breathe. With inflation its just worth less every day anyways. Get a minisplit and get this issue sorted out.
Need BIGGER Building!! Have to have hood open to start painting (Cowl extensions for Intake tubes) to do that Door has to be Open. Need at least 10' Wider to accommodate the truck, could use a 50 or 60x100 with 16' ceiling far better than what currently have. Not ever considered having full size semi in this one.
crane operator
sw missouri
I had to paint in a old gas station stall, it was our only compressor. I don't remember what we were painting, but it wouldn't fit inside. So we built a temp paint booth extension with clear plastic and 2x4's ten foot out beyond the overhead door. I think we had a little box fan as a exhaust fan, and it was quite a fog inside.
So far the fans and a tarp across lower door opening has kept the 'Fog' of overspray down, pleased with that, thought about extension but decided can wait.
Spud_Monkey
Your six
Decommissioned
Entire building 30x48 12’ ceiling so doors on 10’.
Working side 30x30
Truck just happens to be 28’ long
Would barely squeeze in mine too of 32' for length, but plenty of head room here thankfully of 15 +/- feet after slab and rock down.
Shoulda woulda coulda, as to having built bigger. Wife said could not be exceptionally huge to house, even 40x80 x 14 or 16 ceilings would have been my choice with full 12-14’ doors. Shot and shut down long ago.
Mine is encouraging me to go bigger and says I should build another one on other property so I have place to store projects after house is built:eek:
I might add on to current project in the future, I just didn't want to take any more trees out than I already have, along with how it's saddled between hills, ravine and other land features with the direction the driveway goes to follow contours of the property.
As am back to retired I doubt will build anything bigger. If had the money would do a 50x80 on 6” slab and footers. Store my truck and eventual RV inside. Been looking as to rentable structures or property with one could do that in just no luck yet.
In actuality my shop was built to store household crap when built as were also listing the old home for sale and had to "Stage" it, all excess Sh!t OUT. Had to come up with something wife could buy into where could resume working on my own stuff in it after emptied. Entire structure 6" studs, Stick Built on 24" footers with 6" slab was just over $60k insulated and tinned inside.
My other option maybe some day is open up that inside wall, move my Machine tools elsewhere or to a separate structure and where the HVAC is now make that a Ducting slot for a external Wood Heat system where add a Actual Forced Air Furnace and AC system.
