Readying for the KW
Do you remember drilled bolt heads and the tie wire? Glad I never bought one of those “special” pliers for that.
Not sure how much good that wire did but there was a bit of an art to put it in and make it look good and actually look like it could function as intended. Can't really recall taking something apart and finding a loose bolt with wire holding it in place.
As for the cotter keys I felt at least the ones that had the "bulge" part way down them that you had to tap into the hole was a good attempt to keep them from rattling and breaking.
56wrench
alberta
I dunno, but i sure like the idea of safety wire on airplane stuff when i fly:rolleyes:. I use various locking methods on any machine with vibration especially on sheetmetal or brackets. Not so keen on loctite in those applications because it takes too much time. Split type lockwashers are prone to cracking or breaking but i like those serrated(for lack of a better word) and slightly cupped flatwashers on some newer ag equipment. They may be a European or ISO thing but they seem to work
I'm glad the mystery is solved and I don't blame you for wanting to ditch that jinxed block. It seems like you did well to get it out of there when you tick off all the crap that was wrong with that assembly, with clutch, pilot bearing, welded on starter, etc.
i have those special pliers and different sizes of stainless safety wire, the oil drain plugs were safety wired, screen nut, retainer bolt. 1500 hours equals 15 oil changes over the years.
Bought the 4W OS Bearings, Old Block is staying as a Second Thought. Why send this to someone else as a Problem child when can fix it right, and Now.
Bought block AFTER this is back running will be sold. Was a JIC purchase where was only decent one available and satisfied that for me.
Bluox
WA state
Looking at your wrong new bearings I would send that old block to town and have it washed out.
Bob
Engine will go back in as large sectional components, NOT taxing my Hoist and being alone doing this. Will mask off and paint as put major sections together so looks Purty when done this time. The engine may well have just been embarrassed to be seen filthy and threw up on me for that!!
Mobiltech
Sask.
Please tell me you will pull all the oil galley plugs and clean every oil port before assembling
Those mains sure must have rolled in easy with that much clearance. Could have used your dink to push them in I bet!
Willie B
Mount Tabor VT
Electrician
Not criticizing, I know nothing about these engines. The diesels I have rebuilt were 40 HP & less.
You didn't grind the crank. Was it within tolerance? You've likely said how many miles on the engine, I don't remember. Would you be happier truing the crank?
You mention a line bore. How do you need a line bore if you haven't broken a crank? Is this the original crank for this engine?
I went through a broken crank once, wasted a lot of time & money learning why. The subject of line bore came up. I live in the middle of nowhere, but had a race engine builder I had known before he was famous. He measured, & confirmed the block bores were straight, my failure was because of unscrupulous seller, spin a bearing, clean it up, replace with four standard bearings....sell it.
Truck was purchased used prior to me, has 600,000+ecm miles no idea of any previous history or issues prior to coolant leak that busted the head then appears got neglected.
Cat as to what I have read did have a issue with broken cranks a few years on this series and this could be one. Block has been align bored, ended up with oversize shell bearings, indicates had a problem at some point. I did not catch that nor did the new parts supplier as I did give p/n of these and the shell coding. Internally the shells are STD crank, rods were STD. Today was T-day so not much done had a bit of other stuff to do.
new shells and rod bolts.
Willie B
Mount Tabor VT
Electrician
I HATE used machines. More problems from withheld information than original problem. Mostly, sellers cheat buyers. I'm not accusing JY, he too was a buyer.
He had it a short time, likely all the woes this machine has/had were lead in to what he ended up with. All I have found to date were leftovers from long term. Corrosion was from sitting and knew what was getting into. Just let myself get to thinking was gonna be easy fix.
Still a ton of money to get it where I can actually trust it long term to do what I want it to.
