Readying for the KW
oarwhat
buffalo,n.y.
Can I get a condensed version of what happened? I realize the bearings were wrong but why?
I think I got it now. Crank was standard but the block was cut and you ordered standard bearings. Is that right?
56wrench
alberta
Also back to considering on why trusting the OE block, by all inference is a recovered damage block been line bored to correct carnage.
that is one way how an oem salvages an engine core that somebody has traded in:(. Although that being said, that block should go another million miles if everything else is good and the engine gets regular maintenance and is not abused. Its actually a good thing if oversize shells are available for a specific engine. Its cheaper than having the main saddles welded and rebored on a block that may be impossible to find or replace
Cheap "old" Geezer
That is the fact. Mains were called in and emailed photo, was told STD Crank and the bearings came as Standard, no heavy shell.
Tags
Connecticut
Just so I'm following this since I'm no mechanic, the bearings were not the proper size and that is what caused the low oil pressure because the oil was flowing too freely around the mains? But, nothing damaged, besides your pride, correct bearings are available and it all just needs to go back together?
Willie B
Mount Tabor VT
Electrician
Wow! Seems simple now! So many experts, so many know it alls, Who'd have thunk? I feel like plastigauge would have shown a bad fit.
Cheap "old" Geezer
engine is on the floor, upside down
At this juncture have a second block also a BXS that will be inspected and the Jinx sold off.
BTW. The absolute epitome of a Sorry No Count Rotten NO Good classic SOB installed the starter on this engine, 5/8 space saver head 5/8 bolts and had been dipped to the shanks in loctite. Took a two foot piece of pipe on a 5/8 9/16 combo boxed end with enough force to almost flip the block over to break them loose, all 3 of them. Impact would not budge.
