Dmoneyallstar
Just picked up a Case 1845c locally for regular farm/residential putzing around. Will mainly be a forklift for moving a 1/2-ton or less. I know these things are as tough as nails, but you never know who owned one nor what they did and how they treated it. ANYONE RECOGNIZE HER? Bought it in SE MICHIGAN.
Almost walked away when the guy tried to tell me a bogus year plus it left a trail of hydraulic fluid behind it. Got in my truck to drive away and the guy made me an offer I couldn't refuse. Sold. OMG, what did I do?? <genuflect> haaaa
VIN #: JAF0067XXX Any confirmation on a model year? I'm guessing 88-90. The ignorant seller tried to tell me it was a 2001-02, LOL. Also has the yellow chassis with brown cab and earlier "block" decals on arms. Plus...they stopped production in 2000.
Can I call a Case dealer and see if the VIN is in their system for service/sales history? Call it a DIY "carfax" approach.
Got it home. Hydraulic leak was just a loose aux hose. The aux control valve is frozen, so I'm guessing someone was wrenching on it and didn't tighten that line. Topped off fluids and off she went doing some light lifting and normal driving around the yard. Engine bay is very clean and proper. Filters are all newer Donaldson or Case brand.
Tilt hinge pins are a tad loose, but it IS a 4.5k hr machine. However the hourmeter (which works) says 1.6k. I'm guessing it doesn't actually keep proper time, or, it's a replacement gage cluster. The prev owner wrote the oil change hours and date in the engine bay (4.5k done last week). Everything on the gage cluster plus lights work fine.
Diesel fires right up & purrs. Drive is smooth and it tracks straight. No creep or drift. No noises. Radiator has a pin-hole leak right at the filler neck, but only air (above fluid level).
Loader & hand controls work smooth. Right side safety latch is a little stiff, plus I think I can hear the right e-brake pin slipping past the brake holes. Plan to cleanup the pan and adjust. I know a hose is pressing on the cables. Right tilt cylinder is a little tweaked but works and doesn't leak.
Nice newer seat. Cab in good shape.
72" big bucket has a few patches. Needs a few more. I'll prob buy a new low-profile bucket. Quick-attach works as it should.
Needs a new front tire, as it's not holding air and only about 15% tread left. They replaced the front right with new wheel & tire, but front left is an older tire on an original wheel.
Been painted, but could use some sprucing. Last on my priority list.
ANY SUGGESTIONS for specific things to look for? Known issues? Low-hanging fruit?
Like I said, this machine is for my home shop mainly as a fork lift and probably clearing my 6k sf driveway in winter. My little Ford 1210 loader tractor was too little for much lifting.
Wish me luck!
Wish me luck!
