CaptDave
- Joined
- Feb 13, 2008
- Messages
- 57
- Location
- Pickering, Ontario
- Occupation
- Captain Toronto Fire Services
I tried to add a pic of my backhoe but couldn't get it to work.
...it was too big. Geez never heard that before.
I wanted to edit my last post but I can't find that for some reason.
Just a list to add
So right now the list to do is
Fix the seal and bushing in the starter got the parts
Fix the electrical system have most of the parts
Fix the intake heater got the parts
Fix the tachometer got the parts
Fix the brakes working on it
Fix the linkages, brakes and diff lock working on it
Replace the filters Oil, Air, Hydraulic, Transmission, P fuel, S fuel, Power steering Got most of the parts
Replace pins got most of the parts
Reroute hoses no progress
Replace rear tires Need rear 17.5l-24 tire and wheel
Replace lugs on the front tires done
Fix seals on two cylinders the dipper and the boom No progress
Just adding some color and updates on the progress. The red items are the ones that i haven't address yet.
Wengers has a wheel, but no tires.
Thanks,
Phil has been a great help.
I had to take alot apart to replace the brake cross shaft. I can see why it was ever done before. I am going to replace the oil seals on both sides and also the seals and bushing on the center shaft for the differential lock on the right side. I really don't want brake problems in the future.
