I have to agree with Phil, cpelz. I've only worked on triple nickle Fords a couple of times, don't remember that much about them. What Phil is saying is that most all tractor/loader/backhoes have a de-clutch mechanism for various machine operations. One would be with the loader full of material and bucket low to ground, you drive machine to a dump truck to load it. When you near the truck, you need to raise the loader. You press the de-clutch button, this allows you to throttle the engine to raise the load quickly without the drive engaged. Another application would be to de-clutch to shift gears of the manual tranny when selecting higher gears for roading. The de-clutch is usually a solenoid operated valve in the area of the fwd/rev shuttle transmission. That would be between convertor housing and manual gearbox. What Phil is saying is look for a solenoid valve in that area and disconnect the wires from it and see if that makes your problem go away. If so, you can then operate your machine without a de-clutch (which can be annoying) or procede with properly repairing your de-clutch wiring. The de-clutch buttons are normally found as a button on top of the loader control lever, a small pedal or button found on floorplate around the area of brake pedals, and on machines like a later Case machine, there's a button on the handle of the manual tranny shift lever. There ya' go, that should keep you busy for a little while.
