Memories for us old truckers
Cheap "old" Geezer
Mack made the MB into a fire truck chassis, so brilliant in extending the early cabs then DELETING the cab tip over, had to access like a 1930s truck thru Dog House Hatches, SUCKED!!
Now that we are on the subject of fire trucks. This Mack is serial 1001 the first one made out of maybe two. It originally was bought and used by the Montecito Fire Dept in Calif.
Mother Deuce
New England
Geez that would be a cool ride. I need to find a donor one ton... need to make some top bows... little paint
RZucker
Wherever I end up
Mechanic/welder
I love those old K-models. Grew up in the 60's riding around in Grandad's K-10 (?) dumps and the Lowboy tractor burning tons of gasoline. He always said "if you are worried about the gas bill, you're not bidding the jobs right"
In '72 the K tandem tractor got replaced with a '52 Pete with a 262 Cummins... First big truck I got to drive... In the yard. :)
mowingman
SE Ohio
Retired
The old Reo Gold Comet trucks were very popular as ready mix trucks down here in Texas. I had one once, that we converted into a water truck. As I recall, ours had a big old International gas engine in it. I can not tell for sure what kind of gas engine this one has in the picture.
RZucker
Wherever I end up
Mechanic/welder
In high school I worked for a truck repair shop that had an old REO that looked just like that one with a huge old home built wrecker on the back. It was repowered with a Chevy 427, ran pretty good. Seems the story was it was originally powered with a 6V53 Detroit.
Cheap "old" Geezer
Does not look to be IHC power, more White in appearance, Two studs thru Valve Cover for tie downs. Holley 2bbl sitting sideways is different and seems to be leaking water everywhere or rain leaks.
Old Doug
Mo
Was it REO or White that could be ordered with a chevy engine?
RZucker
Wherever I end up
Mechanic/welder
I don't recall that option. REO made a pretty good V-8 of their own for awhile. I think it was around 440 CI and had a pretty good reputation. I think White used it too.
Then there was what they called the Giesel… a gas engine built on a diesel block. I think the base engine was the 504 Cummins V8, that would be a winner, Right?
Cheap "old" Geezer
I do remember that V8 in a Reo at one truck service I worked for, old truck was derelict and sat on a back lot but the engine was visible, gas and roughly the same appearance as a 504/555 with spark plug wires into the valve covers like a Hemi.
I do not remember a GM furnished engine.
RZucker
Wherever I end up
Mechanic/welder
That could be it. I have a 1967 construction magazine somewhere that has a 2 page REO?/Diamond REO ad with pics of that engine.
