Memories for us old truckers
Discussion in 'Old Iron!' started by Truck Shop, Feb 27, 2017.
  1. DMiller
    DMiller Senior Member
    Feb 22, 2010
    5,734
    Retired
    Can still remember the Clictrons we had to install to keep drivers from using the Hot Start systems as a Booster!! Small nasty little temp sensor inline with the power wire, engine or outside temps too warm, not getting any extra Juice!!
    RZucker likes this.
  2. DMiller
    Feb 22, 2010
    5,734
    Retired
    Turbines tried in most every mode of transit. Not so great thru a gear train for as noted the Spool up and need for a reduction gear to get the mass moving, on the locomotives they ran generators where still ran electric motors to the rail wheels. Big problem there was shock loading(Bounce) which caused turbine side shift and incidental housing contact damage along with fuel consumption where at High altitudes worked better, low elevations sucked fuel like a sewer. Great for planes crap for road duty.
    RZucker and Labparamour like this.
  3. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    2,480
    SE Washington St
    At the time when Turbines were being fiddled with and tested for road use, one has to remember-The Jettsons was the cartoon at the time with their dog Astro.
    RZucker and DMiller like this.
  4. crane operator
    crane operator Senior Member
    Mar 27, 2009
    3,633
    sw missouri
    Only land units with turbines I know of, are the abrams tanks. I remember reading their fuel usage specs when they were in Iraq and they need LOTS of fuel. The logistics of moving a armored unit is much more centered around fuel provisions, than pushing back enemy units.
    DMiller likes this.
  5. RZucker
    RZucker Senior Member
    Jul 7, 2013
    3,147
    Mechanic/welder
    Wherever I end up
    I used to wire those injectors so they could only be activated when the starter was cranking. Usually off the crank side of the relay back to the button.
    DMiller and DB2 like this.
  6. RZucker
    Jul 7, 2013
    3,147
    Mechanic/welder
    Wherever I end up
    Anybody remember these things? It's a test :) 20190930_132921.jpg
    DMiller likes this.
  7. Truck Shop
    Dec 8, 2015
    2,480
    SE Washington St
    If IIRC one time one time only
    DMiller likes this.
  8. RZucker
    Jul 7, 2013
    3,147
    Mechanic/welder
    Wherever I end up
    Mechanical shutterstat in the lower tank of a '75 KW. No shutters, I put a Horton fan clutch on it 3-4 years ago.
    DMiller likes this.
  9. petepilot
    petepilot Senior Member
    Jul 7, 2018
    680
    central shenandoah valley va,
    i`ve got a 75 ih gaspot here with a shutter setup similar to that
    DMiller likes this.
  10. Truck Shop
    Dec 8, 2015
    2,480
    SE Washington St
    You answered too fast RZ, DM would have been on that like a bad smell. Twenty years ago the place I worked at had a 74 W900 that had the same setup. It sat for a long spell over winter
    and wasn't used until it was 100 degrees out. It was a fertilizer ten wheeler, the linkage became frozen, shutters didn't open and overheated real bad like.
  11. DMiller
    Feb 22, 2010
    5,734
    Retired
    HAHAHA!! TS thanks for the rub!
    And yes Had I seen it prior to this morning might have been first on!!
    Truck Shop likes this.
  12. Truck Shop
    Dec 8, 2015
    2,480
    SE Washington St
    A heavy one.
  13. RZucker
    Jul 7, 2013
    3,147
    Mechanic/welder
    Wherever I end up
    I bet the chains and binders alone would be more than SuperFord can handle. :D
    DMiller likes this.
  14. mowingman
    mowingman Senior Member
    Jul 11, 2010
    431
    north Texas
    EVERYTHING is BIG in Texas. :)
    DMiller likes this.
