Tugger2
Linkbelt is my guessPoor old B has seen better days as has that suspected D6 behind it, maybe an old American off in the woods?
The distributor on my IH is half way in the cab now they make a setup to put the distributor in the front on chevys. I dont care what engine is in what as long as it runs good and dosent cost alot to keep runing.Actually I couldn't give a damn what engine is used as long as it fits and not shoe horned in place. But them chevy's have the distributor in the back, I don't know how many fire walls
I've seen caved in to accept a Zora Duntoff special.
In 1992? I put a 250HP turbo 3208 Cat in a Ford tandem to replace an 8.2 Detroit. It was a 400 percent improvement. They pulled a 40' dropdeck hauling farm equipment with maybe a 50K gross at times and not very far.Back when Ford heavy trucks were a thing I think I saw more of them with GM motors than anything else. Especially that hateful 8.2. That thing with the blue GM underlined square on the valve cover, it was like a cruel joke from the general to make people hate Ford trucks.
Probably some of the same guys that decided to take a 350 Oldsmobile gas engine and make it run as a diesel! Just because it can be done is not a good reason to do something!Fuel Pinchers, more like wallet gutters. Not the best offering made by DD, always wondered if was a GM engine conversion relabeled as a DD.
Strangely enough, there is a guy here in town that has one that is still running. Overhauled once, he just drives it and doesn't tow or haul anything. Pretty truck, two tone blue and has every option you could get in 1979. Really sounds good too.I remember when these came out in the late 70s as a 1/2 ton pickup with a towing rating of zero, towing not recommended. A ranching friend bought one and put his 16 ft. bumper pull cattle trailer behind it. He ran it with his foot to the floor boards and the slush box transmission in 2nd gear when ever he had the trailer on. It scratched out about 55 mph with his foot flat to the floor. Last I remember he had 180,000 miles on it and still using it to haul calves. It was about the only one I know of that held up to any work.
Back in the 80's when I worked for D&M I swapped out 11 Oldsmobubble diesels to gas 350 or 403 engines. Two of the 403's were four bolt. Because so many people
were changing over to gas the price of a good used 350 hit 1,000 bucks from Smith Auto Wrecking in Ephrata. But still GM and their 350 Olds diesel, the 6.2, 6.5 and
that miserable 8.2 were all piles. Some people had good luck with the 6.5 and some didn't.
If you look close at the original GM 6.2L light diesel and set it next to an old Pontiac big block, the similarities are scary.
The 8.2 was based off the big block Chevy gas engine, and built in Romulus, MI.
The 6.2L was based on the small block Oldsmobile. Sucky as a diesel, but converted back to gas it had a hell for stout block. Batten Heads offered aluminum heads that would bolt on the diesel block for gas conversions. They had some success in the racing world, but Old's racing budget wasn't anywhere near on par with Chevy or Ford. Most blocks were big main journal, so the journals had to be sleeved down and line bored.
