Marine diesel
don`t forget murphy diesel. some big old crane engines. northwest used them in their big stuff
Thank you thank you Pete pilot. At the Union School in White Swan back in 91 or 2, they had a little mom and pop crusher and the jaw was run direct by a Murphy I couldn't remember the name of that till just now thank you.
Yes exactly! I remember you unloaded it to get it started and spun it up. I don't think it was a pony motor but it might have been my brain is fading.
Cheap "old" Geezer
I didn't know there was a tractor called moline, were those any good?
Minneapolis Moline tractors were fairly popular around the midwest. A fairly bright yellow paint color the early units were powered with their own gas and some diesel engines, the company opted to use Hercules a few years as profits waned then bought up by White they were essentially yellow reskinned Olivers with Waukesha engines. They died off in ‘74
kshansen
Central New York, USA
Guy I worked with for years his dad was a retired , I believe, Northwest mechanic and in retirement he did keep working on Murphys in his garage. He actually gave me a couple old injectors, think one is actually a rebuilt one. They came in wooded boxes with wing nuts to hold then together.
At least one model had overhead cams that were run by aa shaft with worm gears at either end. I recall he told me that the worm gears came with no key ways in them. To time the cams you got things lined up and then used some special tooling he had to cut the keyways.
Often wished I had made it a point to go visit him while he was still working on them to see some of the stuff I had heard about.
56wrench
alberta
if i recall correctly, the Minneapolis-Moline tractors evolved from the old Twin-City tractors 1920's ? or earlier. they were popular where i grew up and lots of farms had one back behind in the 'retired' line-up. a Minneapolis-Moline U was the first tractor i was on when i was a kid. in the late 80's i had a 2-150 WHITE which was a 1975 vintage, one of the first grey/black painted models. it had a MM engine (about 150hp) an Oliver over/under powershift, with a Cockshutt/Oliver main transmission and outboard planetary hubs and a closed centre Vickers axial-piston hyd pump. apparently that old tractor is still running:). those were the last of the tractors with an MM engine as far as i know. i worked at a WFE dealership and we referred to the Waukesha-powered tractors a s Knockesha as they had some connecting rod bolt issues, especially on the 310 turbo engines. i still have a copy(maybe) of the factory service bulletin that detailed the new 12point capscrews and hardened washers, and special assembly procedures. after final torquing, the capscrew head had to be trimmed down on one edge to provide adequate clearance to the crankcase during rotation:eek::)
John C.
It's called fire hosing and should have been edited into something more coherent.
Cheap "old" Geezer
Engine hidden in straw pile!!
That it and the boat survived WWII where the boat itself was pre WWI is amazing.
More on the Deltic. Apparently the 22 Deltic locos replaced 55 steam locos. There were also 13 (I think) spare engines so that a power unit could be changed out for a spare instead of trying to repair in situ. I can recall on many occasions seeing a Deltic arrive at a station heading a 13-coach train but only running on just one engine. On flatter sections of the rail network they could still keep to the timetable using less than 50% of the available power.
