Loaders, Limbers and Roadbuilders.
DCT
Oregon
Logger
Chopper95
Colorado
DCT, very cool! I've only seen a few photos of those 3000 delimbers in the past, was never sure how many there were out there.
Jealous of the 2250b as well! Have always wanted to run one of those guys, but not yet.
  • Like
Reactions: DCT
Chopper95
Colorado
Came in to finish the sale off with the 2154D after this guy decided to call it quits.
Caterpillar 522B buncher converted to harvester with an 870B Keto, no squirt; would follow the 830C and process in-woods. And no, our wood doesn't get THAT big. Think he was running that 11BC Oregon .404 chain, the one where the links are about the size of your pinky finger - huge. Most of the guys hadnt seen that before out here; thats all we ran in New Zealand though. Forgot to get a photo of it though. IMG_0024.JPG IMG_0025.JPG IMG_0027.JPG
Chopper95
Colorado
Will get a fatty fir / spruce now and again, everything else is lodgepole pine. Largest tree until the last day had been 153ft cubic
This 37' was 22" on the butt and 17" top - had the fat section of the butt wider when bucking, saw couldnt reach the last bit of it IMG_1613.JPG IMG_1615.JPG IMG_1616.JPG IMG_1618.JPG
Chopper95
Colorado
Then blew that one out of the water with this guy an hour or two later.
25.5" on the butt and 17.2" on the top, 46' stick almost 300ft cubic. I cut another 36' out of the top, another 50 or 75ft cu. , cant recall exactly, and then still had an 8 or 9' junk top.
The 622B really doesn't do well in that size wood; took 4 or 5 tries to buck it even running on the ground and walking the machine - too heavy for the knives to hold and rollers don't get a good bite / slip out since theyre so openIMG_1619.JPG IMG_1621.JPG IMG_1625.JPG IMG_1627.JPG .
Chopper95
Colorado
Final pics for now, from Sept or Oct. Working near Fraser CO, again 9500-10,000ft. Great views of the valley, miserable job though; wood was so small and rotten, had a hard time making enough 37s for the trucks usually to load the 9-18-27 out. No Mules, only long loggers out here. Could had cut 2 or 3 46' trees on the 100 acre job, at least the portion I was working.
Komatsu is a 2014 or 2015 I think, has 7-8k hrs on it. Also have 2017 460 with 2500hrs, but we're trying to sell that one.
280 Prentice on a Canadian C510 Kenworth, 1980 I think. IMG_1435.JPG IMG_1448.JPG IMG_1461.JPG IMG_1463.JPG
Chopper95
Colorado
Hard to say, I have only ever logged at this altitude or even higher so I don't know. Working in New Zealand, we were always coastal, but the machines were much much bigger. Large Cats & Madills, biggest you can buy.
Cooling capacity since air density is a lot less is always my trouble; the processors like to run hot most of the year. Lots of open engine hoods and night work during the summer it seems like. But then emissions issues with it getting so cold and DEF parts freezing.
The sun makes a big difference too. If it is cloudy out, I can see up to a 20-30 degree difference on hydraulic temp during peak day hours, at least lately.
That 2154D is only 160hp which cracks me up cause it's a powerful little machine and no joke only uses like 5-6 gal an hour; I always think something is wrong with my math. Gets around fine and is sized appropriately for the wood, but everyone considers it "big" for out here.
I want to go even bigger though, step to a 300 class or 45 ton machine with actual reach and multifunction, Madill 2850C would be overkill but I want one. I hate running the little processors and loaders.
Chopper95
Colorado
Not logging related, but construction / excavating wise, yes, we have had issues with machines at extreme altitudes.
Projects on top of Pikes Peak, over 14,000ft, we had all sorts of derate / emissions issues. Some machines would only make it a day or two and go down. Others would do fine, but it is very demanding work at that altitude, even on your body. The mechanics would come up and try to fix stuff, but it wasnt uncommon for them to get altitude sickness or just be extremely fatigued.
All the major repair shops are 5-6500ft near Denver or Colorado Springs, so a machine needs to be prepped for high elevations at times. Same goes for the old mechanical ones; Cat had different specs for timing and fuel rates, etc back in the day right on the machine.
Some very flash gear for Colorado standards; newer 2156G (5000hr), 2154D w/ 622B (my daily driver at 13k hrs), and LX830C (10k hrs)
Currently north of Silverthorne, 9500-10,000ft elevation on the job.
View attachment 273591 View attachment 273592 View attachment 273593 View attachment 273595
Small world, we drove by on I-70 last Friday.
EDIT: in Our 07 Ram that went from 281 to 289K on that trip :D
I met ~half dozen new Tigercats on our way East on I-80. Same number of 988K's without buckets and one with, but that's dirt gear. Funny thing I never saw the buckets go by. Maybe they went out on rail?
